NZXT stock fan
Go to solution Solved by WoodenMarker,
They're 1200rpm 3pin fans.
pretty much any case fan will have a 3-pin connector, molex is outdated and has no rpm control. As for the RPM i think it's minimum is 600 and im not sure of the max
Molex is not outdated.
https://linustechtips.com/topic/537177-nzxt-stock-fan/#findComment-7124480
https://linustechtips.com/topic/537177-nzxt-stock-fan/#findComment-7126749
