I am by no means a programmer. I have very limited knowledge on C# and C++ but, I do know enough to tinker around with small things and get them up and running the way I want (sort of).
I was working with a fellow over on the unraid forums on setting up a PowerShell script to automatically convert my video media to a format this is more suitable for viewing no an iPad using handbrake CLI.
It was basically doing a "Watch Folder" set up. One of the issues I had with the script is that well basically I couldn't get it to run. The PowerShell window simply opens and then simply closes. When I use the default variables for the folder to be watched and the output segment the window stays open for a while (I assume looking for those paths). However, when I change them it as I said before simply closes outright.
This script would be running on a fresh install of Windows 10 Pro on a VM of an unraid server with the latest version of PowerShell.
Attached is the PowerShell Script.
I did not write this. It seems that the guy who did is away for a while and I'm really wanting to get this up and running on my server.
The main problem is that when I run the script on either the VM or my local machine after I change the target locations the script opens and then instantly shuts down.
When I run the script from the PowerShell editor I receive this error:
+ $Host.UI.RawUI.WindowSize = $sizeWindow }
+ CategoryInfo : NotSpecified: (:) [], SetValueInvocationException
+ FullyQualifiedErrorId : ExceptionWhenSetting
Another idea I had for the script (I wish I had the know how to do all of this), was to add a feature that gave the user the option to either convert files currently in the folder and watch the folder for new content, or just simply set it up as a watch folder script.
I am aware there is software that will "Watch" a folder for changes. However, those software are not automated. However, if anybody knows of something different I can run on my VM that will accomplish all of this for free I'm all ears.
Thank you very much in advance for anybody's help. I'm not much of a coder and if I need to make changes go easy on me.
If this is not the place for this post please let me know as I will not make that mistake again.
Again Thank you.
FileSystemWatcher.v1.1.ps1.txt
The Box - Unraid NAS
Case:  LIAN LI PC-A77B PSU: Seasonic X650
CPU: Xeon E3-1230 MB: SUPERMICRO MBD-X9SCM-F-O Memory:Crucial 16GB (2 x 8GB) DDR3 SDRAM ECC Unbuffered DDR3 1600
HDD Controler: SUPERMICRO AOC-SASLP-MV8 & SUPERMICRO AOC-SAS2LP-MV8
Storage: 5x WD Red 4TB (one set as pairty drive) 5x WD Green 2TB HDD Accessories: 2x SUPERMICRO CSE-M35T-1B 3 x 5.25 (replaced included fan w/ Noctua NF-B9-1600)
Gaming system:
ASUS ROG G750JH Laptop (plan to buy a desktop eventually)
https://linustechtips.com/topic/536081-help-with-powershell-script/
Any help on this, please?
Gaming system:
No luck. Doing the exact same thing as before. I'm not sure. :| No errors when ran w/in the PowerShell editor. However, it just simply closes
I think I'm going to give up on this endeavour.
Gaming system:
