I have a GTX 980 and I want to test to see if it is stable after an ESD incident. What testing software should I use and what settings? And while benchmarking is lag normal?
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/535856-lag-normal-while-running-a-2-hour-benchmark/
If the card cant run it then lag is normal, the ESD Incident will not cause damage, GPUs are very resistant against it now.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
Explain what software and settings I should use please
Use firestrike on a loop, or Unigene heaven, set all to loop and Extreme preset on heaven.
