Hi I'm going on holiday soon and I'm looking for a wifi solution it can run off mains power or battery and it needs to provide a good signal for YouTube and Internet browsing. Can all websites or prices be in UK pounds please
Thanks in advance
Tomic
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
https://linustechtips.com/topic/535773-portable-wifi-solution/
Thanks in advance
Tomic
If there is Ethernet available, buy a Kingston 5-in-1 and a cheap Ethernet cord.
Kingston 5-in-1: http://www.amazon.com/Kingston-Companion-Storage-Charger-MLWG2/dp/B00KU2E9IW/ref=sr_1_1?ie=UTF8&qid=1453926657&sr=8-1&keywords=kingston+5+in+1
Cheap Ethernet cord: http://www.amazon.com/Mediabridge-Cat5e-Ethernet-Patch-Cable/dp/B003O973OA/ref=sr_1_14?s=pc&ie=UTF8&qid=1453926751&sr=1-14&keywords=cat5e+cable
For cellular edition, try going with some sort of bell division:
- Bellsouth east (AT&T)
- Bell Canada
- Bellsouth west
- bell idk
-etc.
Edit:
Just saw that you live in London. Vodafone is supposedly the best in London.
i like trains 🙂
https://linustechtips.com/topic/535773-portable-wifi-solution/#findComment-7108961
Go to car-phone-warehouse, ask for the EE Mobile Wifi Box, I pay around £30 a month for a 20GB download limit. It runs on its own battery or plugs in to a micro USB to charge. Works on 4G so speeds are amazing and the wifi signal is brilliant!
HIGHLY recommended.
http://www.carphonewarehouse.com/broadband/mobile-broadband/buy/huawei-4g-mifi-di103-idcon?intcmp=mbbLP_iD_paym_20pm_201015
Enjoy and look no further
https://linustechtips.com/topic/535773-portable-wifi-solution/#findComment-7117297
Will you be moving around a lot during the holiday? If your staying in just one or two hotels, just bring a normal router. Pre-configure it as a AP and safe all the passwords ahead of time and then just connect the ethernet to one of the LAN ports. If the hotel charges per devices, you can clone the WAN MAC to that of your computer.
What in general would you be connecting the router to? Wifi connection with password? Hotspot with sign in? Wired connection? Cellular?
https://linustechtips.com/topic/535773-portable-wifi-solution/#findComment-7128323
