What voltage/multiplier would you guys recommend for a stable air cooled i7 4770k?
I recently purchased a Noctua NH-U14S as my stock intel cooler was not sufficing, I had turbo mode activated so it would bring my speeds up to about 3.85ghz under stress it would reached above 85 celsius.
I want a slight overclock hopefully around 4.2ghz but I want it as stable as possible, whilst using minimal voltage as I want to reduce as much temperature as possible.
Do I need to turn turbo mode off?
Any advice would be amazing, thanks.
System specs:
CPU: i7 4770k stock
GPU: EVGA 780 SC
MOBO: Asus Maximus VI Hero
RAM: Corsair LP 2x8GB DDR3 1600Mhz
https://linustechtips.com/topic/535630-need-experienced-overclockers-help/
What stress test are you using? If Prime, what version?
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
Try 4.5 ghz, 1.25v.  If your chip is atleast halfway decent, it should do this.
Should I leave turbo mode on? I dont want my CPU running at 4.5ghz constantly only when its under pressure
Turbo mode has nothing to do with that.  Just don't mess with C-states or EIST in the BIOS.
