Java While Loop (Help!)
Go to solution Solved by elpiop,
wrong syntax, should be name.length()
My assignment is to ask the user to enter a name that has to be 5 characters or more. If it is less than 5 I have to repeatedly ask them again and again.
So far I have all of the usual input java.util.*;
Declaring a new scanner "Scanner kb = new Scanner (System.in);"
And initially asking for the name "System.out.print("Please enter your name (minimum 5 characters): " );
String name = kb.nextLine();.
Now here is the part that I am stuck at, the while loop. So far I have
"while (name.length < 5)" and I am getting an error "cannot find symbol between the name and length."
I also tried converting the string into an int with "Integer.parseInt", that compiled fine but if I type in anything besides a whole bunch of numbers I get an exception.
Please help, thank you.
https://linustechtips.com/topic/535489-java-while-loop-help/
