Hey techie's,
If a pc makes a high pitched noise while off does this mean coil whine ? And if yes is this something a manufactor will replace under waranty.
When the Pc powers on the noise disapears.
Sorry for the bad grammer i bet i misspelled a lot xD.
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
https://linustechtips.com/topic/53463-coil-whine/
Must be your power supply.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/53463-coil-whine/#findComment-717678
its not my pc its from a customer of ours and i hav no clue besides this and i was thinking idd coil whine in the PSU like bluejay sayd. But cant verify this havent seen it yet only heard about the complaint.
https://linustechtips.com/topic/53463-coil-whine/#findComment-717749
Can you post specs of the client's PC, please? I would love to assist you.
https://linustechtips.com/topic/53463-coil-whine/#findComment-717762
unfortunatly not i only know its a slim acer pc i only wanna know for the customer if its something coverd by waranty or not before i send it of for repair and get a giant bill xD
https://linustechtips.com/topic/53463-coil-whine/#findComment-717778
Well. An Acer, huh? So desktop... power supply! or dedicated graphics card.
https://linustechtips.com/topic/53463-coil-whine/#findComment-717784
im guessing since it only happens when the pc is turned of it is most likely the PSU to bad i dont have the pc here atm to verify this xD but still no closer to coil whine being a warranty issue or not xD
https://linustechtips.com/topic/53463-coil-whine/#findComment-717789
It is the power supply; they still have current going through them when they are off.  Most power supply vendors will replace a unit for coil whine, but you would have to check with Acer to see if their warranty covers it.
https://linustechtips.com/topic/53463-coil-whine/#findComment-717793
