hi
i need some help guys im currently in need of advice i really like the noctua nh d14 air cooler but heard of ram issues i have the corsair dominator platnum ram
if i remove the heat spreader will it fit also i have a choice of the h80 but i afraid of watercooling and leaks help!
https://linustechtips.com/topic/5341-cpu-cooling/
I'd go the H80i if you have already got Dominator Platinum however if you haven't got that RAM yet, go for low profile such as the Corsair Vengeance and get the D14 as it performs better by a few degrees.
as mentioned also, it's very rare to have a leaking AIO and the benefit is that if it does leak you've got a strong case against Corsair for their product damaging your system - something you wouldn't have if it was a custom loop.
https://linustechtips.com/topic/5341-cpu-cooling/#findComment-61206
