Hi everyone
Here are my problems.
1) In the table there is a field "Date". How can I make a request, if it is a reserved word in SQL? Rename field is impossible.
I make a request to the DataBase Desktop: select Date from "Sales.DBF", displays the message: Invalid use of keyword
2) making a request:
select ListNo, sum (Amount) from "Sales.DBF"
group by ListNo
It displays a message "Operation not applicable". Where is the mistake?
https://linustechtips.com/topic/533709-i-have-two-problems-with-dbf/
Hi everyone
Are you using FoxPro or SQL or what on the DBF?
Hope these help:
1.)
SELECT * FROM Sales FOR [DATE] = {^2016-01-25} 'Or whatever your date is
2.)
SELECT [ListNo], (SELECT SUM(Amount) FROM [Sales.dbf]) AmountFROM [Sales.dbf]GROUP BY [ListNo]
 Almost as cool as my temps
Hope these help:
1.)
2.)
Nice ansver. I agree. And if it doesn`t help I suggest you to stop waisting your time and use this program DBF Repair Kit. You can find it here http://www.dbf.repair/
