I have been trying to get this problem to install to help with OC and controlling my fans.  When i go to click the installing it acts like its going to... and then nothing.
I have googled it and tried several things. Like... making sure EVERY .exe is set to run as Admin. Running one problem.  Ended it in task manager and running the other half of the problem.  Nothing has worked so far.
 Anyone have any idea, or have you ran into this problem before? I am downloading it from the manufactor's page.
Motherboard - Z97-AR ASUS
Chipset - Haswell
Southbridge Z97
BIOS Version 1204
BIOS Date 06/20/14
Running WIN 10.
https://linustechtips.com/topic/533423-ai-suite-not-installing-help/
make sure you downloaded it from the right page. AI suite has different versions for different motherboards.
https://www.asus.com/Motherboards/Z97AR/
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
I wish I could give you my AI Suite. I never use it, but I don't want to disable "Run at startup" because reasons.
Gaming PCs:
Intel i7 4790k, EVGA GTX 980ti, NZXT H440
Intel i5 7600k, Asus GTX 970 DC Mini, Silverstone SG13B
HTPC: AMD Phenom II X6 1045t, EVGA GTX 770 FTW, Fractal Node 604
