I just got a new fanless psu and it has a high pitched coil whine while outside the case, haven't tested the noise level with the case. The noise varies between on and off, but is always on. Is this normal? Is it fixable? Is there even a way to slightly reduce it?
You can try to RMA the psu, but I've never had a coil whine device before.
• OS: Windows 10/10 Pro  • SSD: Samsung 256GB 850 Evo Series *  • HDD: Seagate 1TB  • GPU: MSI GeForce GTX 1070 GAMING X (SLI)
• CPU: i7-4790K OC 4.7GHz Quad-Core Processor • Case: NZXT H440 (Black/Red) • PSU: EVGA SuperNOVA NEX 650W
• RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory • Mobo: MSI Gaming 5
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076207
coil whine isnt really bad, my psu used to do it but it stopped after  about a week
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076220
i had an EVGA 750W supernova which had very bad coil whine when under GPU load but was silent on idle...i called EVGA and they refund me through newegg...EVGA is a special kind of animal though, not many companies will accept to do something like that...coil whine in a device is generally not considered as it being faulty.
It might go away over time...does it get better or worse when it's under heavy load? (gaming for example)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076264
Actually quite the opposite... The more power it uses the quieter it is.
It's loudest when the computer is off.
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076319
then, i would believe it might go away after some time...run it heavy for a while and see what happen...make it get real hot! :D
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076327
Nothing you can do as it's a PSU.
Best is to ask the seller or manufacturer (if they offer direct support) for a RMA replacement unit. Then hope for the best your replacement will be better.
What PSU did you get anyways?
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076336
Ss-520fl-2
I see...well, if it makes you feel any better, my RM750X makes coil whine when OFF. Very very quiet but it's there. Goes away once I turn on the system lol.
Btw, if you ever think about returning it instead of replacing it, you can get the RM1000X for a bit more. It operates fanless until 500W.
https://linustechtips.com/topic/533189-coil-whine/#findComment-7076752
