C Programming: caesar cipher for lower case letters only
Go to solution Solved by MeshFile,
Put the condition before the
input[i] = input[i] + rotate;
I have this code which uses the caesar cipher encryption method based on a users input, so the user enters the text then they enter the amount of times they want to shift the text.
However I was wondering how I could make it so only the lower case letters would be shifted as specified.
I was thinking of adding something like this:
if (input[i] >= 97 && input[i] <= 122)
But i'm not sure where to add it in my program which is this:
#include<stdio.h>  #include<string.h>  int main()  {        int rotate, i;        char input[80];        printf(" Enter the text you wish to be encrypted: \n");        gets(input);	        printf(" Enter the amount of times you want to rotate: \n");  	        scanf("%d",&rotate);  		        if (rotate > 26)      rotate = rotate % 26;  //0 <= rotate < 26.        for(i = 0; i < strlen(input); i++)        {            if(input[i] == ' ')           {            continue;        }       else        {             if(input[i] >= 'x')             {              input[i] = input[i] -26;              }             input[i] = input[i] + rotate;            }       }	       printf("Your encrypted text is: %s\n", input);  }
Could anyone advise me on this? I need only lower case letters to be caeser ciphered.
One thing I will point out is that you shouldn't use gets. It causes memory leaks and is a security risk. Use fgets instead.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
I did try that but it just gives me errors. gets seems to work
The formatting with fgets is bit different.
fgets(name of array, size of array, stdin);
The stdin indicates that is scanning standard input. You have to  specify that because fgets can also be used to read from files.
Read more here: http://www.dummies.com/how-to/content/how-to-use-the-fgets-function-for-text-input-in-c-.html
I did this some time ago .
void cypher(char *str, int offset){    for(int i = 0; i < strlen(str); i++)    {        if (islower(*(str+i)))        {            *(str+i) = ((26 + ((*(str+i) - int('a')) + (offset % 26))) % 26) + int('a');        }        else        {            /*Whatever*/        }    }}
strlen() is from string.h .
islower() is from ctype.h
And of course, you use it something like :
   char c[100];   fgets(c,100,stdin);   cypher(c, 13);   printf("%s",c);
