Phanteks Case Fans Software?
So I"ve had my PC for a while now but I've never been able to find the software needed to change the fan speeds for my Phanteks Enthoo Pro's fans.
Does anyone know where I can find it?
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/531551-phanteks-case-fans-software/
Are they 3pin fans?
Just look in your BIOS, there should be fan curve speed settings there
3pin fans cant be controlled unless you use a fan controller
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
There isn't a proprietary software or anything like that to control your case fans.
If your fans are connected to your motherboard, you can usually control them through your motherboard settings or software like SpeedFan.
Your options for software are:
- Whatever your mobo has (requires fans connected to mobo)
- Speedfan (same as above)
- NZXT CAM and Corsair Link (requires Grid+ or Commander Mini fan hub)
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
