I believe you should be able to to overclock that CPU with that board. I just overclocked a similar CPU (E8200) a few hundred Mhz to 3200 or so using a board of the same chipset.
http://www.overclock.net/t/429337/gigabyte-ga-p31-es3g/10   <- An page like this might be of use to you.
https://linustechtips.com/topic/529860-overclocking-pc-help/#findComment-7029977
Can you post some guide how to do that. What to change in BIOS or else.
Personally, I don't post guides or links to guides on OC'ing as I don't want any responsibility/liability should anything go wrong. Answering your question of if you can I can do, but how? I recommend researching what settings in BIOS there are and what effects they have on the system. This information, or guides can be found with a Google search.
https://linustechtips.com/topic/529860-overclocking-pc-help/#findComment-7030446
http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/529860-overclocking-pc-help/#findComment-7031186
