[Help] MySQL phpMyAdmin [Help]
Hi, i need help guys.
How can i make there on my Database when user is registred 'user_id' is AUTO_INCREMENT and i have two tables in on database.
Database name: pelqimetemia
Table 1: users
Table 2: balance
and what i want is a new registred user goes to users, i need to automatically send user_id from users to user_id bilance. same user_id in table users same for user_id bilance for that user.
Thanks
https://linustechtips.com/topic/529776-help-mysql-phpmyadmin-help/
You can user trigger (example: http://www.techonthenet.com/mysql/triggers/after_insert.php ) just after inserting your user you can get last insert id and insert new balance row with new user id, it somehow depends on language you use and driver but, I say kind of because mysql has a function  LAST_INSERT_ID that you can use in a query and it will return last inserted id per client, so even if your driver doesn't wrap it up you can use it directly by.
