I'm not aware of any consumer solutions, however you would need something to cool the liquid. If the liquid was in a large enough volume, ambient temperature would be enough, and this is the workings of an oil cooled pc. If you found some sort of endothermic device (small refrigeration unit perhaps?) you could do it. Sounds like a cool (heh, excuse the pun) little project.
https://linustechtips.com/topic/5286-fanless-system/#findComment-60675
You can make a fanless PC without using water at all. If you had a 360 rad on just the CPU that would be enough to cool the CPU fanlessly.
You would also need to think about the VRM, GPU and PSU as well has the hard drives and pump.
You could do it. In fact I will be doing it. I plan to have my fans off while my PC is at idle and just have 1 140mm fan to direct the airflow.
You also have to remember that the rads would have to be horizontal because air has to rise through them.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/5286-fanless-system/#findComment-60685
You can get radiators designed for passive use. They're very large, I've seen builds where the uses have very large cases and bolt the rads to the outside of the side panels.
They're called alphacool cape cora.
You can do it with air too:
passive psu, passive gpu, passive mobo, then use a NoFan cpu cooler.
https://linustechtips.com/topic/5286-fanless-system/#findComment-61501
Yes ;)
But if i shall answer serious, i woud say that you can put the fans outsite the case, but still it wont fanless.
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/5286-fanless-system/#findComment-61539
