I need some help deciding on what CPU I want to upgrade to.
I am currently using an i7 2600k and I want to upgrade to skylake, I don't know whether I want to get the i7 6700k or i5 6600k for such a lower price. I am primarily using my computer for gaming but every once in a while I do use 3d design programs like blender.
Is the 6600k better than my 2600k?
Is the 2700k worth the money?
https://linustechtips.com/topic/528374-major-upgrade-help/
2600K doesn't need upgrading
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012064
Well the 2600k isn't going to bottleneck 1080p, so just get a better GPU.
If you already have a beast of a GPU the 6600k is plenty for even intensive CPU games.
considering games use HT now, a 6600K would be the same OR SLOWER than a 2600K
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012096
In most cases, but still need to consider for those odd developers. :/
4720HQ master race ^_^
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012165
I don't want to spend that much money especially since the CPU upgrade also requires a new motherboard and ram.
Right now I have a r9 280x but I plan to upgrade it to a r9 390.
I just don't know if the i7 is worth the extra money.
i7 2600K can drive ANY SINGLE GPU on the market. A 390 will be no issue.
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012194
Ahh
Okay buy another R9 --- <Insert the 3-- series card and XFire it.
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012198
Ahh
280X didn't get rebranded so he can't do that.
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012226
Oh shit.......
AMD only refreshed Hawaii this year. Fiji and Tonga are new
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012241
I know I just want to future proof my computer, the 2600k is already 4+ years old, the only reason I got it was because I got it for free from my brother after he built a new computer, so it can be said the old parts are well used.
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012453
CPU development is stagnate. Until Zen comes out nothing really worth getting from either AMD or Intel.
https://linustechtips.com/topic/528374-major-upgrade-help/#findComment-7012536
