What is better for 3d rendering?A processor with 4/8 or 8/8? Can i see some graph,video or something like that?
Naming said processors would be very helpful.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
What do you mean 4/8 or 8/8? As in, hyperthreaded quad-core vs true octa-core?
Can you reference some CPU models?
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
Thanks, Sauron! )
But I will say this more correctly
4 cores 8 threads vs 8 cores for rendering in 3d
Again naming the actual CPU's is the only way anyone will be able to give you an accurate answer. an i7-2600k (4/8) up against an FX-8 (8c) is completely different from an i7-6700k vs FX-8, and that's without even considering clockspeed (only IPC).
AFAIK there is no Intel CPU with 8 cores and no HT, unless you have specifically turned it off. If that is the comparison you are looking for say so.
