What is wrong with my PC?
Solved by suchamoneypit,
A simple thing to check would be to make sure the cables arent lose, with my DVI cables sometimes it will get loose and colors and cause a weird look. You GPU could also have died. Try another monitor and/or cable to double check that.
Vibora ·
Posted in New Builds and Planning2 -
2
3
Doctah ·
Posted in Peripherals1 -
5
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards3 -
Packhunter ·
Posted in Graphics Cards5 -
12
6
play_circle_filled
Latest From ShortCircuit:
