Ubuntu help
Go to solution Solved by EpicAdom,
I tried like 4 times should I keep going lol
Have you tried reinstalling onto your flash drive? Your bootable usb might have installed incorrectly.
My brother is planning on using ubuntu 14.04.3 on his pc. Anyway so I'm booting it from a usb and I press install ubuntu, it does its thing and then it gets to the home screen (the purple background and whatnot) and then it just goes to an orange screen and gets stuck there. Any help would be appreciated
https://linustechtips.com/topic/527464-ubuntu-help/
Installation probably fucked up, happened to me a couple times. Just try to install again
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
https://linustechtips.com/topic/527464-ubuntu-help/#findComment-7000435
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
https://linustechtips.com/topic/527464-ubuntu-help/#findComment-7000543
