BitFenix Alchemy LED strips.
"And yet my mind is screaming, provoked in an icy sweat. It’s pleading and begging for a release, scraping the walls of a padded cell, pounding hopelessly at the floors that won’t even deliver the gift of pain."  - Why I Don't Dream Anymore
https://linustechtips.com/topic/52727-led-case-lighting/#findComment-706809
I have a personal preference for Phobya light strips, They have a good throw, Nicely sleeved cable and plugs into a fan header instead of a proprietary connector that goes into a Molex passthrough Which means you can hook them up to a fan splitter PCB which makes cable management alot easier :D
I found the Phobya's cable's to be to short and the solder between the wire and strip terrible like it was pointed out in the video.
https://linustechtips.com/topic/52727-led-case-lighting/#findComment-706814
anyone got a quick review  for me on the NZXT Sleeved LED Kit? @Blackterror25
I wouldn't get them. They're annoying to install and are too obtrusive in the case. Just grab any that are "LED strips". They just stick right on to the case. Unless you want the ability to turn on and off your LEDs, then grab the NZXT ones for ease.
https://linustechtips.com/topic/52727-led-case-lighting/#findComment-706849
