trying to help a friend fix her hard drive. She gets this error "vli product string" tried googling but none of them were of any help.
What exactly is wrong with it?
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/526972-hard-drive-problem/#findComment-6994401
~snip~
Hey there piperz_stanne,
What is the drive's brand and model? What is your friend's PC (desktop, laptop, etc.)? What OS is she using?
This may be connected to drivers as well as the connection itself so more data is needed before we can help you. :)
Post back!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/526972-hard-drive-problem/#findComment-6994808
