I've paired Bluetooth speakers to my PC but they aren't appearing under Plakback devices in the Sound menu, even after a restart.  How do I make them my default audio output device?
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/526448-pc-audio-through-bluetooth-speakers/
The Asus Sabretooth z77 doesnt have bluetooth, unless you already have a bluetooth adapter then you will be needing one.
Here is a cheap one I have: http://www.ebay.com/itm/311448502996?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Might add this later...
I have a Bluetooth adapter, that's how it's already paired.
My Bluetooth adapter is listed as V2.0 under Devices in Windows 10 but the speakers are V3.0 on their spec sheet.  They managed to pair but could this be the problem?
Yes that will be the problem most likely, get a version 3.0 or 4.0 for $3 and see if that fixes it.
