http://linustechtips.com/main/topic/154956-how-to-properly-set-up-speedfan/
I have follow these steps above and I labeled all my fans and check if the speedfan works and it did, but for some reason my fans which is linked to CPU in advance fan control menu ramp up to 100% when my cpu is getting intensive task or around 50% utilized. I am using the 4.52 Beta 4. I am able to run the fan at 1100RPM at full load using AIDA64. Why does the fan need to ramp up ... it weird.
Is sometime with my motherboard over righting speedfan?
I have noctua N-HD15 and 3 Venturi HP-14 140mm.
i7 6700k
MSI 980ti
Sabertooth z170
Define R5
Magical Pineapples
https://linustechtips.com/topic/526346-weird-issues-with-speedfan/
I can't give direct settings right now (on laptop), but there's setting where you point limits when CPU is thought as hot. Like min and max values for fan. Set that max temp to where you actually want fan to ramp up. Not where you think CPU full load temp is.
I'll post detailed answer when I'm home. If you still need one.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Try capping speed in part circled in red. Does your Speedfan auto-startup at login work as well?
Well i have tried at, yes it autostart up. I have just installed thermal radar 2 and seem fix my problem.
Magical Pineapples
