Using Intel onboard graphics!
Solved by Philcat101,
Most of you are going to tell me that ideally I want to always have a discrete gpu but just hear me out.
I have an i5-4690k and plan to get a gtx 970 gigabyte g1 gaming but because of the current hole the canadian dollar is in, the prices are higher than I want to pay.
My plan is to just build my rig and run it on the onboard graphics to install drivers and download programs I use and maybe just surfing the web (no games whatsoever). Then switch to a discrete card when I can.
My concern is if this will lower the life of my cpu.
What are your thoughts on what I should do?
It won't.
The lifespan be just fine as long as your temps don't go too high (which is not going to be affected by onboard graphics so...)
