Alright, time for the final check to make sure everything will work. Exhibit A. The diagram (made with my lovely MS paint skills, note, I will be switching cases, power supplies and most likey, Chipsets in the time)
Now onto the parts to be used for said project
https://shop.ekwb.com/ek-tube-zmt-matte-black-15-9-9-5mm-3m-retail (1x Ek-Tube, matte black 15,9/9,5m)
https://shop.ekwb.com/ek-acf-fitting-10-16mm-black-2 (8x WK-ACF 10/16mm Compression fittings)
https://shop.ekwb.com/ek-vardar-f4-120er-2200rpm (3x EK-Vardar F4 120ER)
https://shop.ekwb.com/ek-coolstream-se-360-slim-triple (1x EK-CoolStream CE 360 Slim Triple)
https://shop.ekwb.com/ek-xres-140-revo-d5-pwm-incl-pump (1x EK-XRES 140 Revo D5 PWM  Including Pump)
https://shop.ekwb.com/ek-supremacy-evo-acetal-nickel-original-csq (1x EK-Supremacy Evo - Acetal+Nicke)
This should all work correct? there shouldn't be any conflicts? (360mm Rad for GPU support later)
https://linustechtips.com/topic/526094-final-check-with-custom-loop/
https://shop.ekwb.com/ek-coolstream-ce-420-triple (1x EK-CoolStream CE 420 Triple)
Not my area of expertise, but could you not get a high quality AIO cooler and replace the fans with high pressure models?
The performance increase in using custom cannot be that much better, can it?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Amazing MS Paint skills lol (I'm just trying to joke around)
Anyway, I think that should all work, but I'd wait for other people to look
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
Well they said they wanted to put the GPU in later, soooo
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
it can infact be better, I personally wanna ditch my loud h100i, and take pride in not having an AIO anymore.
And I don't really wanna get off too easy with a whole watercooling kit either.
And again. Like I said, It can be better, but it really depends
Looks good but you do have an extra 2 compression fittings and no fuild
I recommend you measure that before you buy or you can get the smaller version which is the same as im using.
I'll be sure to measure it just in case, because I just saw this $100 in tax xD
It'll be another 4 monthish after I get a PSU and case to even consider buying the pump
