Hi guys, I'm using a Galaxy s3 (us) and am running Cyanogenmod 10 (not 10.1) and I need some help:
1. EDIT I FIGURED THIS OUT: In the File manager, I can't move files. It says "error detected: this operation is not permitted in this folder".
       how do i fix this? it won't let me edit permissions and i have set root access.
2. How do i change how much the brightness power toggle changes brightness by?
       I had found the menu before but now can't find it.
3. In the Lockscreen > Screen Security menu why are the additional options not changeable?
      they are gray and cant be changed.
thanks for all your help!
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/52569-cyanogenmod-help/
