Get a graphics card.
I own and use, sorted from newest to oldest: SteelSeries 6Gv2. Microsoft SideWinder X4. Mionix Naos 7000. Zowie EC1 Evo. Microsoft SideWinder X8. Microsoft IntelliMouse Explorer 3.0. Dell U2414H. Samsung P2270H. AKG K273 Pro. Sennheiser HD555. Razer Goliathus Speed Medium. Func 1030 L. Qpad CT Medium.
I used to own: Razer DeathAdder 3G. Razer Krait. IntelliMouse Optical 1.1. SteelSeries QcK.
https://linustechtips.com/topic/524049-help/#findComment-6957817
Well you could probably get an adapter for HDMI to Display port but it wont be 144hz,
You probably should have a actual GPU instead of running off the iGPU,
With the actual GPU you should have a display port capable of 2k @ 144hz
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/524049-help/#findComment-6957821
I have a gtx 980ti but I just realized I accidentally removed it
https://linustechtips.com/topic/524049-help/#findComment-6957877
Just connect the monitor to the gpu.
The performance would be worse going off the iGpu/motherboard.
https://linustechtips.com/topic/524049-help/#findComment-6958178
