Would I able to mount the rad for the h100i in the front of the case.
https://linustechtips.com/topic/523267-enthoo-pro-m-h100i/
yeah you can :)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/523267-enthoo-pro-m-h100i/#findComment-6949042
I mean the front of the case not the top just wondering if the tubes will stretch
looks like you can (skip to 5:00)
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/523267-enthoo-pro-m-h100i/#findComment-6949137
yes you can.
look at hardwarecanucks' video.
Old Rig
https://linustechtips.com/topic/523267-enthoo-pro-m-h100i/#findComment-6949147
