Nope
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/52237-radiator-fans/#findComment-698833
What are you cooling?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/52237-radiator-fans/#findComment-698837
Nope
Rig CPU Intel i5 3570K at 4.2 GHz - MB MSI Z77A-GD55 - RAM Kingston 8GB 1600 mhz - GPU XFX 7870 Double D - Keyboard Logitech G710+
Case Corsair 600T - Storage Intel 330 120GB, WD Blue 1TB - CPU Cooler Noctua NH-D14 - Displays Dell U2312HM, Asus VS228, Acer AL1715
https://linustechtips.com/topic/52237-radiator-fans/#findComment-698839
Not much
CPU: Intel i5 3570k 4.2GHz with Corsair H100 RAM: Corsair 16GB (4x4) SSD: Samsung 840 120GB HDD: Seagate Barracuda 1TB GPU: Strix GTX 1080
PSU: OCZ 650W CASE: Fractal Define R5
https://pcpartpicker.com/user/MelchiorVester/saved/#view=RKNXsY
https://linustechtips.com/topic/52237-radiator-fans/#findComment-698958
@Ghost can help you. As long as it's not a a rad with high fpi you should be fine.
Depends what "noticeable" means and how you define "performance". I doubt you will notice the fans are quieter because one is missing. You won't be able to get any higher overclocks because the temp change will be too insignificant. You you will be able to notice the temp difference as that's usually on a scale of 0.1C.
The question was too vague for a definite answer.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/52237-radiator-fans/#findComment-699003
Sorry I was in a rush, its a rx360mm, just wanted to make sure it'l be fine with the temps, ( i'm cooling a 3770k, and two 7970's using a modified 800D (240 Rad in the bottom)
https://linustechtips.com/topic/52237-radiator-fans/#findComment-699061
Of course you will. One fan really doesn't make a difference.
https://linustechtips.com/topic/52237-radiator-fans/#findComment-699216
to make the look, push or pull will be fine on that build. only thing would be a deal
breaker would be if trying to run the fans @ 5volts.
airdeano
https://linustechtips.com/topic/52237-radiator-fans/#findComment-700673
