I have just received my new Asus vg248qe by mail. I currently have it hooked up to my laptop vi HDMI. I know I not able to push 144hz as I am building a gaming PC right now. When I play games I get some terrible screen tear, however, it is only at moments, not all the time. The games I play run at 60 FPS almost all the time. Is there any chance I can diagnosis this problem? Will it continue on my new PC at 144hz? Thanks.
https://linustechtips.com/topic/52224-screen-tear-help/
 Why did you buy a 144hz monitor but you play games at 60fps?
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/52224-screen-tear-help/#findComment-698715
have you selected that refresh rate on the videocard control pannel and hdmi cant go 144hz
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/52224-screen-tear-help/#findComment-698717
Use adaptive Vsync it might help. I think it will lock it into 60 but if you make a custom settings in the Nvidia control panel I think under custom resolution you can set your monitor to output at 144Hz constantly.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/52224-screen-tear-help/#findComment-701340
60hz is the max you can go for now.
You will get tearing if the video card is delivering frames out of sync with the monitors refresh, which is possible above and below 60FPS (more common above)
If you enable vsync you will not get tearing because it forces the cards to sync each frames for transmission to the monitor after each refresh cycle (or something to that effect).
With your laptop GPU you may struggle to maintain 60 FPS so you'll drop to synced at 30 unless you have:
adaptive vysync enabled (nvidia)
or
the AMD equivalent (3rd party radeon pro software iirc)
https://linustechtips.com/topic/52224-screen-tear-help/#findComment-704999
