i7 4790k temps
Go to solution Solved by W-L,
Just installed a 4790k. Everything is on stock right now, no overclock. I'm also using the stock cooler. Planning on getting a 212 in the next week or so. Tried stress testing it with Aida64 for a good 15 mins and my temperature on 100% load was about the mid 70s range. Is this a normal temperature especially when using the stock cooler?
I would say it's about right, not unexpected from the Intel cooler.
https://linustechtips.com/topic/522210-i7-4790k-temps/
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935109
Also - I tried testing with Prime95 and the shit skyrocketed my temps to the low 90s. I did read however that there's some sort of incompatibility with haswell chips and prime95, is this true and should I be worried?  :unsure:
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935122
Yeah don't use Prime 95, it pushes the CPU far too hard giving unrealistic results. As for the hyper 212 you should be able to keep it fairly cool, it depends on the chip but maybe 55C on stock which will allow for a fair bit of overclocking.
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935143
Dont use Prime ever. Period.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935155
That's what I thought! Thanks so much man!
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935161
I can probly drop ur voltage if ur at stock speeds to 1.16 v but make sure u set it on the vcore offset
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6935739
I just wanted to give you an update! I just installed a hyper 212 and my temps are at the 50s now on aida64. Thanks so much for the help man!
Edit: Spelling
https://linustechtips.com/topic/522210-i7-4790k-temps/#findComment-6950646
