All I want is a good looking reversed ATX case! Shouldn't all cases have thus option, I mean we are in 2016! Could you guys please suggest me a reversed ATX case, that doesn't look like just a box!
Like the Corsair 600Q, btx type case:
http://www.corsair.com/en-ca/carbide-series-quiet-600q-inverse-atx-full-tower-case
https://linustechtips.com/topic/521434-reverse-atx/#findComment-6925029
"One reason for the failure of BTX to gain traction in key markets was the rise of energy-efficient components (CPUs, chipsets and GPUs) which require less power and produce less waste heat, eliminating two of the primary intended benefits of BTX. Another reason was the lack of OEM adopters."​
Taken from Wikipedia directly, don't know how to properly quote external sites.
Intel was developing it because it was better for heat dissipation, and then they were all like "why don't we just make our chips better" and didn't bother with BTX anymore.
Some OEM computers (the old tower MacPros and some Dells) are run modified BTX, but at that point they're just using totally custom layouts.
When in doubt, re-format.
https://linustechtips.com/topic/521434-reverse-atx/#findComment-6925110
