Hi,
I have recently set up 2 IP Webcams with two of my old android phones (This is the app) and I was wondering if there was any way that the two cameras could be shown on one page with controls for both them.
Attached is a picture of the webpage that is used for one camera at once.
Thanks,
Slinky0
post-125112-0-84551700-1452049440_thumb.
https://linustechtips.com/topic/521412-ip-webcam-grid-help/
-snip-
You may be able to use this:
http://www.deskshare.com/ip-camera-viewer.aspx
They technically are IP cameras.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/521412-ip-webcam-grid-help/#findComment-6924926
