You should just put it at the lowest setting possible for lowest latency. It controls how long each PCI device can hold the PCI bus before another takes over. There's no point in setting it higher unless you are getting some kind of rare error/bsod. More info: https://en.wikipedia.org/wiki/Conventional_PCI#PCI_bus_latency
My rigs:
NEW Ryzinator build:
CPU: AMD - Ryzen 9 3950X 8-Core Processor
Motherboard: Asus - PRIME X370-PRO ATX AM4
RAM: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 @ DDR4-3066
Storage: (3x) Samsung - 850 EVO-Series 500GB 2.5", Samsung - 960 EVO 250GB M.2-2280
PSU: Seasonic Prime TX-750
OS: Microsoft - Windows 10 Pro 64-bit
Additional fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan
Case: Fractal Design - Define R5 (Black) ATX Mid Tower Case
GPU: ASUS Radeon RX 580 Dual OC 4GB
Display: MSI 27L Optix MAG272QP @ 165Hz
OLD Build (SOLD):
CPU: AMD FX-6100 Motherboard: ASRock 960GM/U3S3 FX (VRM overheating, don't buy) RAM: 8GB Kingston ValueRAM GPU: Onboard ATI Radeon 3000 Graphics Case: Corsair Obsidian 500D Storage: Hitachi HDS721010CLA332 1TB, 119GB SAMSUNG MMCRE28G5MXP-0VBH1 (SSD), 465GB Western Digital WDC WD5000AZRX-00L4HB0 (SATA)  PSU: Be quiet! - Straight Power 10 400 Watt Cooling: Cooler Master Hyper 212 EVO OS: Windows 10 Pro x64
Retro gaming build:
CPU: Intel Pentium 3 Coppermine @ 800MHz Motherboard: Asus P2B i440BX BIOS 1012 FSB: 133 MHz RAM: 1x 128MB Hynix PC133 SDR SDRAM GPU: ATi Radeon 9200 256MB AGP Case: Full Tower case (unbranded) Storage: CompactFlash card to IDE converter (16GB card) Sound Card: Aztech 2320 ISA Cooling: Stock heatsink fan OS: Windows 98 Second Edition
https://linustechtips.com/topic/521083-pci-latency-timer-help/#findComment-6920329
You should just put it at the lowest setting possible for lowest latency. It controls how long each PCI device can hold the bus before another takes over. There's no point in setting it higher unless you are getting some kind of rare error/bsod.
Thank you so much, and also thanks for the quick reply :)
https://linustechtips.com/topic/521083-pci-latency-timer-help/#findComment-6920341
No problemo :)
My rigs:
OLD Build (SOLD):
Retro gaming build:
https://linustechtips.com/topic/521083-pci-latency-timer-help/#findComment-6920359
  • 5 years later...
