Im having issue with my usb wifi driver could not be loaded etc. Today i manage to fix it with system restore. Then another problem occur.
The wifi is fine now, but this ralink utility for odd reason its not running on booting, and this keep coming out (refer the pdf / link)
Doc1.pdf
https://linustechtips.com/topic/520646-ralink-and-usb-wifi-problem/
Have you tried reinstalling all the drivers + utility? Also OS it the most up to date version for windows 10?
Check starting programs in task manager to make sure its set to open on boot
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
