CPU: FX-8350
Mobo: Gigabyte 990FXA-UD3
I've been using easytune to overclock my cpu. I have it set on "Extreme" to get 4.5 gHz. However, when running cinebench, this is what Open Hardware Monitor reads
https://gyazo.com/c0cb2c4ed82fef476b0484148d8b108c
I noticed that some cores are running at 4119MHz instead of the rest being 4320. It also changes cores randomly.
This was taken a few seconds after
https://gyazo.com/e59956852f374b70c62f980a3c8aa4d8
I have no clue why most of the cores are running at 4320 when they should be at 4521 due to cinebench running 100% CPU.
I have no past experience with overclocking and have no clue what I'm doing. Any and all help will be appreciated.
Thank you!
https://linustechtips.com/topic/520641-amd-overclocking-help/
