I'm buying a mobo. Either Micro ATX or ATX. I don't really NEED an ATX, though I do have an ATX case right now and I might later decide to go for a micro ATX case.  This is for portability. I'd prefer it not being a mid tower case.
The case needs:
5.25" external bay
Enough space for my CPU cooler (Dark Rock Pro 3 163mm in height)
Decent air cooling
Space for my MSI 390 GPU (277mm)
Side Panel EDIT: Windowed
Bonus:
Dust filters would also be nice, but not too vital.
5 PCIe slots in the back in case I decide to crossfire my MSI 390 (takes up 2.5 PCI slots). Probably won't do that though.
Space for a 3.5" hard drive - though I might just go for a 2.5" hard drive and use the 3.5" for backup. Though I would prefer not doing this. Makes more sense to keep the 3.5" HDD inside the case - the 1TB WD Black is also very loud!
Anyone have any suggestions?
Edited by Alir
https://linustechtips.com/topic/520398-ultimate-compact-micro-atx-case/
I love the Silverstone SG10 but it doesn't have a full sized 5.25" bay.
I only love my DVD drive because it plays blu ray discs and comes with free software to play blu ray discs
*EDITED: Also needs space for my MSI 390 GPU (277mm)*
bitfenix prodigy m
Apparently it has poor cable management and looks like it won't support my CPU cooler?
What about Xigmatek Aquila?
Is it possible to include a 5.25" dvd drive in the top with one fan in the top AND have my CPU cooler?
The case needs:
5.25" external bay
Decent air cooling
Side Panel
Bonus:
Phantek's Enthoo mATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854009&cm_re=enthoo_matx-_-11-854-009-_-Product
Although I prefer their Mini ITX version
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854015&cm_re=enthoo_itx-_-11-854-015-_-Product
You might also wanna look at the new Corsair Spec Alpha case
https://youtu.be/PXeUhNqie34?t=3m19s
cpu cooler wise, with the prodigy m, you should be fine for clearance if you dont' use the hard drive brackets.. (I have one)
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
Raidmax hyperion
Silverstone tj08e
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Btw, what do you mean by side panel? Windowed?
