anyone else having problem with Razer Ouroboros mouse?
It's weird problem?
When this mouse goes to sleep it changes x or y axis speed to slowest possible. Most of the time it's x axis that is slow and I have to vigorously move my mouse and change dbi to ¨wake up¨ that x axis to start working in that dbi I have putted it in setup.
https://linustechtips.com/topic/52018-ouroboros-problem/
I have this problem, all I did was change the DPI using the button up and down and it should be back to normal  just in a few sec
Intel 4770k : 4.6Ghz @1.285v | Asus Maximum VI Extreme | Asus GTX780 DCUii OC | Corsair Vengeance Pro 16 GB @2400mhz| Corsair AX1200i |
Samsung 840 Pro 256gb | Random mix match 3.5" hard drives |  Asus PB278q
Cooling : EK Supremacy Plexi/Nickle | Swiftech MCP655 Laing D5 | XSPC RX360 | EK D5 X-TOP CSQ |
https://linustechtips.com/topic/52018-ouroboros-problem/#findComment-695820
It's a common problem, there's also the stuttering problem when you change DPI
https://linustechtips.com/topic/52018-ouroboros-problem/#findComment-695836
