Hi
I recently build a computer and after about a month of use i encountered a sudden drop in frame rate and it continue would to run at a low fps. This would happen after about an hour of play, usually after i had spent a extended amount of time in the in-game menu ( upgrading a character for example). The highest temperature I've seen on the GPU is 88ºC. I've tried clean installing gpu drivers using DDU and that didn't did fix the problem.
PC specs:
i7-6700k
Asus z170 pro gaming
Kingston 32gb DDR4
asus 980ti strix
Evga supernova g2 750w
CoolerMaster Nepton 240M
Samsung 850 evo
WD black
edit: running windows 10 64bit
Thanks.
https://linustechtips.com/topic/520151-sudden-frame-rate-drop/
Uptade GPU drivers, but if it's updated, you can downgrade to last known good version of drivers
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/520151-sudden-frame-rate-drop/#findComment-6909691
Sounds like a gpu overheating Issue. Try reapplying a new coat of thermal paste to your gpu.
that voids asus warranty I think.
I7-6700k @ 4.8Ghz, EVGA Z170 Classified, Corsair Vengeance LPX 4x8 32 GB, EVGA FTW+ ACX 2.0 GeForce GTX 980ti 6 GB x3, 2Tb WD Black x3, 1Tb Samsung 850 Evo, 400Gb Intel NVME PCIE SSD, Corsair RMx 850w 80+ Gold, Corsair Strafe Cherry MX Brown RGB, SteelSeries Sensei Raw
https://linustechtips.com/topic/520151-sudden-frame-rate-drop/#findComment-6910076
Then no choice but to RMA the card If there's an Issue or Turn up the fans and live with the noise.
on the 750ti there is a warranty sticker on the screw same with 970
https://linustechtips.com/topic/520151-sudden-frame-rate-drop/#findComment-6911059
is that the same cooler they've been using on all the cards over the past three years that stopped being effective almost two years ago because they didn't redesign it for the newer archtecture?
didn't you try ramping up the fan speed manually at all?
https://linustechtips.com/topic/520151-sudden-frame-rate-drop/#findComment-6911760
