24 Pin power cable
Go to solution Solved by Naeaes,
Changed the link
Coolio. :D I just spat out the answer but have now verified. The beveling here is different from what's here. That's a Corsair AX1500i compatible with the cable you asked about. Probably Corsair did that because their pinout isn't compatible either. Anyhoo... This cable should do for you.
Hello all
I have broken my 24 pin power cable (do not have pictures) but My dog has gotten hands on it while I was upgrading to a new case.
I have an OCZ 1250 80+ Gold power supply (Link Below)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341046
Will this cable work for the 24 pin slot
https://www.ple.com.au/ViewItem.aspx?InventoryItemId=612309
Thanks All
https://linustechtips.com/topic/520142-24-pin-power-cable/
Changed the link
https://linustechtips.com/topic/520142-24-pin-power-cable/#findComment-6909179
Thanks Man but just found out that the one my dog chewed was the one from the cable mod pack
Kind Regards
Hanno
https://linustechtips.com/topic/520142-24-pin-power-cable/#findComment-6909224
