Ok so i have this weird problem with Photoshop cs6. I have two monitors hooked up one to the dedicated gpu and one to the igpu. Now the problem is when the igpu or should i say if i enable the second display hooked on the igpu and when i try to launch photoshop i get launch errors saying it has detected problems with the display driver and if i want to use photoshop without the gpu settings enabled it just crashes. And if i turn off the second monitor everything goes back to normal. Now this is really frustrating since i use the second monitor for quick synch recording and every time i need to use photoshop i need to disable the second display and whenever stop using it i have to enable it again.
What i suspect is there is a conflict between the igpu and gpu that photoshop detects. A way around would be for photoshop to be forced to use only the dedicated gpu but i have no idea how to do that.
Any help would be appreciated.
Rig:Crimson Impaler | CPU: i3 4160 | Cooler: CM Hyper TX3 Evo | Motherboard: Asrock B85M - DGS | RAM: Kingston Hyper X Savage 16GB kit (2x8) DDR3 1600MHZ CL9 | GPU: Asus Radeon R7 360 | PSU: Corsair CX 430 V2 | Storage: HDD WD 1TB Blue | Case: Delux DLC-MG866
~Half the world is composed of idiots, the other half of people clever enough to take indecent advantage of them.~
https://linustechtips.com/topic/518433-photoshop-igpu-gpu-problem/
Why do to u need to conect the 2md monitor to igpu it won't make a different if you hook them up to the dedicated
Have not touch ps in a long while but try to set your primary monitor in properties the one connected to dedicated
lives on
BAKABT
I have the second monitor connected to the igpu because i need it for quick synch. The monitor connected to the dedicated gpu is already set as primary.
