Hi, I am finishing a build and have a Gigabyte 980ti Windforce. It didn't come with a manual and there are 2 8 pin connectors on the right hand side of the card. It came with a two headed cable, do I plug both heads into the card and then connect the other end to a VGA cable and into the PSU?
Thx
Intel i7 6700K @ 4.7 GHZ...Gigabyte Z170X Gaming 7 Rev. 1.0...Gigabyte 980TI Gaming G1 "Windforce" (x2) in SLI...Samsung 950 Pro M.2 NVME SSD 512 GB...Corsair LPX Vengeance DDR4 2400 MHZ 32 GB (8x4) Black...NZXT Kraken X61 (Top) with 2 Noctua NF-A14 PWM LTT Edition Fans and White Noctua Chromax Pads...Corsair Carbide Air 540 Arctic White Case with 1 Rear Noctua NF-A14 PWM LTT Edition Fan and 3 Front Noctua NF-F12 PWM LTT Edition Fans and White Noctua Chromax Pads...Corsair AX1500i PSU...CableMod White & Black Replacement Cables...Windows 10 Home...LG 34UC97 1440p 21:9 60hz Monitor...Ducky Shine 4 Keyboard...Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/517794-power-for-980ti/
Thx
That is just an adapter they provide, you can use a DVI, or HDMI which is what most displays use now.
As for the PCI-E connectors lookon your PSU for a PCI-E or VGA connector for both the 8 pins
Edited by W-L
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6882657
So the VGA cables the providr have one head that is 8 pin and on the other end a 6 pin plus 2 pin. How would this work?
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6882858
You would need to plug both in the 8 pin and the 6+2pin into the card to power it, make sure they are both labeled VGA or PCI-E power cables.
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6882885
There is another VGA cable that has 8 pin on one end and 6 pin plus 6 pin plus 2 pin. Do I use this one to plug in the 6 and 6 and leave the 2 pin dangling and then the 8 pin onto psu?
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6882887
Oh you mean something like this that came with the GPU?
If that is the case you don't need it if your PSU has two 8 pin PCI-E power cables.
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6882891
Thanks!
Working now.
I plugged in two cables. An 8 on one end (PSU) and 6x2 (into graphics card), and a second cable the same.
Just curious. What is an okay idle temperature? I got to the BIOS and it says it is 29 degrees celsius. All fans are on including Noctua D15
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6883072
Thanks!
Working now.
For the GPU that's good, but for load temps if you overclock it keeping it below 85C is good, similarly for the CPU.
https://linustechtips.com/topic/517794-power-for-980ti/#findComment-6883140
