So it just sounds like a sort of rattle, but when i put pressure on the sidepanel it stops, but if i put too much it sounds like something metal has gone into a lawn mower, why is this? Also pressure on the front stops it (until i let go), just was putting pressure on the front and it has reduced it by a lot for some reason even when i took my hand off, i think it will come back and always does it when i turn it on. sounds like it could be towards the psu (i have it on hybrid fan mode).But its weird if i put pressure on most places of the case it temporarily manipulates the volume of the sound. Also it usually does that sound 10 minutes after turning it on and sometimes in extended use would keep coming back.
[CPU] Ryzen 5 3600x [Cooling] be quiet! Dark Rock Pro 4 [Mobo] B450 Tomahawk Max [RAM] 16GB (2X8) Corsair Vengeance LPX 3000MHz [GPU] RTX 2070 Super Gaming X Trio [PSU] XFX XTR 750W [Case] Fractal Design Define R5 Windowed
https://linustechtips.com/topic/517281-rattle-in-case/
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876635
please quote people if you want to say something to them, otherwise I can`t see it.
 Maybe your fan isn`t oriented correctly, but at worse it could be something else in the PSU itself, but please open up your case and make sure where the sound comes from.
That way we can narrow the answer down to one component
to game or not to game, that`s the question
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876646
I will open up the case later and properly check more stuff but  it usually does that sound 10 minutes after turning it on and sometimes in extended use would keep coming back.Could that narrow it down?
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876655
than it could be a heat problem, I`m not good at PSU stuff, but could be some transistors. If I were you I would search for site or forum where the same problem is displayed
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876658
I doubt it would be transistors lol. I bet your side panel is rattling and when you put too much pressure on it, it is shoving a wire into a fan. This isn't really the place ti troubleshoot problems like this, as simple diagnostic skills should do the trick for you ;)
My native language is C++
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876690
hahah okay, that`s why I said I don`t know anything about PSU stuff, all magic to me
https://linustechtips.com/topic/517281-rattle-in-case/#findComment-6876729
