The problem is quite simple. One of my 7970s fan does not speed up. It stays at a constant low rpm. Even if i manually adjust the value in Catalyst or Afterburner it makes no change.
I'm not running the new crimson drivers so that i don't think is the problem. I've used the other 7970s are a control and the fan spins fine. The issue persists even with just that ome card installed.
Any thoughts?
|i5 3570k @4.4Ghz | Asus Maximus V Gene | 8gb Corsair XMS3 | 2 x MSI HD7970 OC @ 1175mhz | 512gb Crucial M4 | Corsair AX750 | Fractal Design Define Mini | Dell P2416D
https://linustechtips.com/topic/516809-reference-7970-fan/
Just an update, but I updated drivers and flashed a newer bios for the card. Neither worked.
https://linustechtips.com/topic/516809-reference-7970-fan/#findComment-6871462
