So I've had my 980 for about a year now and I would like to overclock it. I'm very new to OCing so I'm not entirely sure what to do. I watched a couple videos, so I get the whole concept and stuff. Here's a screenshot of EVGA Precision X, with my current settings (Which are default). What should I cranked up? I would like something that gives a nice boost but will be stable.
https://linustechtips.com/topic/516726-evga-980-sc-overclocking-help/
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
You can apply voltage after a benchmark crash.Put 10mv and see if it passes the benchmark.For memory start from +250 and +50 if the oc passed the benchmark.Keep incrementing until you crash
Okay, so if it passes add 50 MHz on GPU clock, and add 50 MHz to the memory clock. If it fails, add 10 mV or dial back 15 MHz or so on the GPU clock. That sound about right?
First try to reach your max core clock,and then do the memory alone
Watching your GPU-Z sensors after benches would be more telling.
But yes, that's well within safe voltage, without BIOS flashing, you're always pretty safe with software overvolting - though as a beginner, still always small steps...how are your temps.?
Honestly, I'm surprised you'd need to apply voltage at all to hit those speeds.  I'm right with ya @ 1520ish core/8200 mem on stock voltage.  Usually (in my experience with three different 900 series cards), overvoltage often allows *slightly* more stability while *slightly* limiting boost.
Watch temps and what your PerfCap is in GPU-Z...you may think you're maxing performance by gaining stability with the displayed boost clock, while in reality, you're inserting another artificial ceiling to limit boost.  You can boost beyond the shown one on GPU-Z's window there.
Watch your sensors, that will show you what you're hitting and why.  Nice OC speeds BTW. :)
