Newly Built Computer, Screen Wont Boot? Help?
So i built a new computer, i have everything plugged and was gonna start the boot. All the lights are on inside, fans are on, gpu light is on, lights on my usb Mouse and keyboard is on etc. i connectedy hdmi to the MOBO and GPU hdmi slots and nothing showed on my screen. help? Also Im using a tv
CASE: NZXT S340 CPU: Intel i5-4690K MOBO: Gigabyte GA-Z97X RAM: Corsair 16GB GPU: MSI R9 390 HDD: WD Blue 1TB SSD: Samsung 850 EVO 250GB PSU: XFX ATX12V/EPS12V 650W
https://linustechtips.com/topic/516275-newly-built-computer-screen-wont-boot-help/
is it the build in your sig?
remove the GPU
reset the CMOS
run with one stick of RAM
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Don't reset the CMOS quite yet.
You may want to check to make sure that the TV input is set correctly. If you didn't manually and explicitly change the input, then that's why.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
TV's can take much longer than a monitor to recognize a signal. Sometimes you have to wait for that to happen. But, do try to use the motherboard output first without the GPU. The TV may also have scaling issues that should be able to be fixed through some menu on it with an overscan option or something pertaining to PC input.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
