I just got a Cooler master N200 for a fresh build and I noted that the stock fans conectors have a molex end (4 pin). It appears that this molex end (atleast for me) is actually a removable adaptor so the fan is really a 3 pin so I tried to remove it with no sucess (I didn't applie much pressure because I was afraid I would break it). Since the motherboard supports only 3 pin fans and I don't want to connect it directly to the psu because it won't have speed control (right?). I thought it was a good idea to ask here if the molex end is or isn't removable.
https://linustechtips.com/topic/516192-cm-n200-fans/
I think it is removable. They are just adapters I believe. Used the case to host a home theater. I replaced all the fans though with some cheap ones off of newegg.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/516192-cm-n200-fans/#findComment-6865127
