Need help with rig upgrade
Go to solution Solved by Searinex,
This is what I would upgrade. Also I would not use that PSU, it's not even 80+ and could kill your computer.
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card  ($199.99 @ Newegg)
Other: Turbo-X H61M
Total: $289.97
Generated by PCPartPicker 2015-12-29 16:50 EST-0500
Hey guyz, i have a 5 year old rig and need to know if i can do some upgrades to game in high settings 1080p or should i buy a new one with the thought of 1440p gaming in the future(always on a budget. The hardware i intent to keep from this current built, if possible, is:
CPU: Intel core i5 2320: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115091
MoBo:Turbo-X H61M: http://www.plaisio.gr/anavathmisi-diktia/anavathmisi/motherboard-mitrikes/Turbo-X-H61M-HDMI-s-1155-DDR3-H61-H61M-HDMI.htm
PSU: Turbo-X 550W: http://www.plaisio.gr/anavathmisi-diktia/anavathmisi/psu-trofodotika/Turbo-X-550W-Value-Series-II.htm
also hdd which is 1TB no problems with that and  cooler which i can seem to find right now cause i am not sitting near that built right now. everything else is pretty much for upgrade. i have 2x2gb ddr3 ram 1333mhz and an AMD radeon 6770HD those are what i would like to replace. Thank you for your time in advance and lastly the budget i am going for is 250 euros.
https://linustechtips.com/topic/516079-need-help-with-rig-upgrade/
Other: Turbo-X H61M
Total: $289.97
Also welcome to the forum, and don't forgot to follow your posts.
Other: Turbo-X H61M
Total: $289.97
it seems good but i think the mobo only supports ram @ 1333mhz but other than that i agree on the psu part and thanks!!
also will this support the AAA titles @1080p for a good period of time?
