GPU Temps
Go to solution Solved by Sportiva,
Those temps are perfectly fine, you should start worrying if they get up to around 90 degrees.
Hey guys.
Should I be concerned that one of my cards run at between 75c & 80c when playing Witcher 3?
Running everything maxed at 1440p 60fps.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/516028-gpu-temps/
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/516028-gpu-temps/#findComment-6862862
